Opis produktu
WOSSNER TLOK MAICO MC490/GS490 '80 (86,42MM).Product DetailMaico Motorcycle 2 Stroke OffroadPart Number 8036DABore Size 86.5 mmClearance 0.08 mmCompression Height 41.7 mmCompression Ratio Cylinder No.
1 Cyl./KitDisplacement 498 ccDome Volume Engine Code Piston Weight Stroke Valves/Cylinder Gasket P/N Lock P/N CW18Pin P/N WP042Ring Set P/N RSC8650Rod P/N Product FitmentSelect your car to see if this product fits:- 1981 Maico 490 Base- 1981 Maico 500 Base- 1982 Maico 490 Base- 1982 Maico 500 Base- 1983 Maico 490 Base- 1983 Maico 500 Base- 1984 Maico 490 Base- 1984 Maico 500 Base- 1985 Maico 490 Base- 1985 Maico 500 Base- 1986 Maico 490 Base- 1986 Maico 500 Base- 1987 Maico 490 Base- 1987 Maico 500 Base- 1988 Maico 490 Base- 1988 Maico 500 Base- 1989 Maico 490 Base- 1989 Maico 500 Base- 1990 Maico 490 Base- 1990 Maico 500 Base- 1991 Maico 490 Base- 1991 Maico 500 Base- 1992 Maico 490 Base- 1992 Maico 500 Base- 1993 Maico 490 Base- 1993 Maico 500 Base- 1994 Maico 490 Base- 1994 Maico 500 Base- 1995 Maico 490 Base- 1995 Maico 500 Base- 1996 Maico 490 Base- 1996 Maico 500 Base- 1997 Maico 490 Base- 1997 Maico 500 Base- 1998 Maico 490 Base- 1998 Maico 500 Base- 1999 Maico 490 Base- 1999 Maico 500 Base- 2000 Maico 490 Base- 2000 Maico 500 Base- 2001 Maico 490 Base- 2001 Maico 500 Base- 2002 Maico 490 Base- 2002 Maico 500 BaseWszystkie znaki handlowe i nazwy firm, zostaly uzyte wyłącznie w celu informacyjnym i sa wylaczna wlasnoscia tychze firm....
