• Producent: GATES
  • Kategoria: Termostaty samochodowe
  • Marka pojazdu: Ford
Opis produktu
Termostat płynu chłodzącego silnik producenta GATES do samochodu FordWindstar 3,0 V6 1995-2001Windstar 3,8 V6 1995-1995Windstar 3,8 V6 2000-2003 wartość za 1 szt Zamiennik dla:Autotemp 1-195CARQUEST 13009CARQUEST 30209Chrysler 3224216Chrysler 4494469Chrysler 52028185Chrysler 52028185ABChrysler 52028446Chrysler 83504856Chrysler J8127383Delco Harrison 132-67Ford Motor Co. D4PZ 8575 AFord Motor Co. D9TZ 8575 AAFord Motor Co. E0TE 8575 EAFord Motor Co. E1BZ 8575 AFord Motor Co. E5TZ 8575 CFord Motor Co. E6AZ 8575 AFord Motor Co. E6AZ 8575 BFord Motor Co. E6DZ 8575 BFord Motor Co. E6SZ 8575 AFord Motor Co. E7ZE 8575 AAFord Motor Co. E8TZ 8575 AFord Motor Co. E8TZ 8575 BFord Motor Co. F2SZ 8575 AFord Motor Co. F3TZ 8575 AFord Motor Co. F4PZ 8575 AAFord Motor Co. F4TZ 8575 BFord Motor Co. F58Z 8575 AFord Motor Co. F5DZ 8575 AFord Motor Co. F6CZ 8575 AFord Motor Co. F6DZ 8575 AAFord Motor Co. F6TZ 8575 HAFord Motor Co. F6ZZ 8575 AFord Motor Co. XL2Z 8575 ABFord Motor Co. XR3Z 8575 BAFord Motor Co. YF1Z 8575 BAGates 33509Gates Canada 33509General Motors 12323753Ideal Aftermarket 30009Ideal Aftermarket 30109Ideal Aftermarket 32159International 1807945C1International 1807974C91International 1807974C92International 1807974C93International 1807974C94International 807974C1International 807974R92Lazorlite L33-9035Lazorlite L33-9045Lazorlite L33-9055Lazorlite L33-9155Mazda ZZM415171Mazda ZZS115171Mopar 3-727Mopar 3-752Mopar 3-753Mopar 3-771Motorcraft RT-1024Motorcraft RT-1025Motorcraft RT-1029Motorcraft RT-1058Motorcraft RT-1067Motorcraft RT-1067AMotorcraft RT-1087Motorcraft RT-1105Motorcraft RT-1107Motorcraft RT-1108Motorcraft RT-1111Motorcraft RT-1114Motorcraft RT-1120Motorcraft RT-1139Motorcraft RT-1152Motorcraft RT-1155NAPA 269Opel 1338016Opel 1338018Robertshaw 300-195Robertshaw 400-195Robertshaw 401-190Robertshaw 705-185Robertshaw 728-195Standard Thomson 269Stant 13009Stant (Carded) 36309Stant (Small Card Retail) 29309Tridon Aftermarket 1195Tridon Aftermarket 119ETridon Aftermarket EX5488Tru-Temp 650HTWaltham W269 Termostat to jeden z głównych komponentów układu chłodzenia zarządzający długością obiegu chłodzenia. Do momentu osiągnięcia 88 'C płyn chłodzący krąży w tzw. Niedługim obiegu. Ciecz kierowana jest przez pompę do silnika i do nagrzewnicy (ogrzewanie wnętrza pojazdu). W obiegu pełnym płyn chłodniczy przeprowadzany jest poprzez chłodnicę, która obniża jego temperaturę.skutecznie działający termostat nie może się zacinać, a dodatkowo jego minimalny otwór odpowietrzający musi być cały czas czysty i w pełni drożny. Jeśli zostanie zatkany, w termostacie pojawią się pęcherzyki powietrza, które mogą utrudnić jego poprawne działanie.Mogą wystąpić dwa warianty awarii termostatu:- zniszczenie w pozycji otwartej, wtedy temperatura cieczy chłodzącej jest wtedy zbyt niska, a silnik nie może osiągnąć temperatury roboczej, nie działa lub działa niezwykle słabo ogrzewanie kabiny oraz pokaźnie wzrasta zużycie paliwa.- uszkodzenie w pozycji zamkniętej, wtedy ciecz chłodząca nie ma możliwości przepłynięcia przez chłodnicę i schłodzenia się, w rezultacie gwałtownie początkuje się nagrzewać, nie mogąc odprowadzić ciepła z silnika co może doprowadzić do jego przegrzania!!!...
