Zestaw OPTIMUS Elektra Fe Cook System
chwilowy brak towaru
  • Producent: Optimus
  • Kategoria: Naczynia i niezbędniki
Opis produktu
Model: mini kuchenka; rodzaj: kuchenka jednopalnikowa; rodzaj paliwa: gaz; stosowne paliwo: Butane, Propane; z zapłonem piezoelektrycznym: tak; ilość podpór: 3; sprawność (Watt): 3000 W; Czas palenia: 1.5 (220 g gas cartridge) h; Czas gotowania (min): 2.3 (0.8 l, depending on climate) min; rozmiar (dł.
x szer. X wys.): 12,4 x 16,5 cm; Waga: 455 g; komplet: tak; Zakres dostawy: Crux Lite cooker, piezo-igniter, windscreen, Terra Weekend HE cooking set, cooker bag; szczegóły: BTU: 10'200, Material: steel, aluminum, powerful and highly efficient cooking system - reduces cooking time and fuel consumption aby up to 20, Thanks to its compact size, the cooking system fits in any backpack and weighs very little, separate piezo igniter for convenient and reliable ignition of the cooker, attachable windscreen made of hard anodised aluminium, Terra Weekend HE cooking set made of hard anodised aluminium with non-stick coating, Heat Exchange heat exchanger ring at the bottom of the pan reduces cooking time and fuel consumption, certified according to CE-048BN-0045, CSA certified
