Opis produktu
Model: materac nadmuchiwany cieplny; typ: komfort; Samopompujące się: tak; Materiał zewnętrzny: 100% poliester; Grubość: 76 mm; Grubość maty: komfort; objętość opakowania: 15 x 15 x 30 cm; Waga: 910 g; Długość (cm): 196 cm; Szerokość (cm): 63 cm; Parametr izolacyjności: 2.2; w dodatku worek do trasportu: tak; detale: Material: 75D polyester double diamond (top), 75D polyester (bottom), 7.6 cm strong supporting force, ideal for those who sleep on their sides and love to be comfortable, Speed valve pulls air from the environment and increases the volume of the injected air, Compared to conventional valves, the mat can be inflated in just a third of the time, air can be released in a matter of seconds, higher-lying edges prevent nocturnal slipping, Pack bag and repair kit
